on 25-05-2024 09:59 AM
I am trying to connect my Archer router and am having problems. Existing connection working with talk talk router.
Seems I can't get an IP issued to the router . Have done a factory reset on router and noted the settings required by talk talk for 3rd party router.
VLAN ID :101
MTU: 1500
DND: Automatic
Authentication: DHCP/IPoE
When I go to the settings in the router there are other VLAN ID settings which are set to zero ,and the router requires some value other than zero.
Is there something that talktalk need to do their side to allow the router to work ?
So I am wondering if this is the problem.
Any help appreciated.
on 14-06-2024 10:53 AM
on 14-06-2024 10:49 AM
I've only been with tiscali/tt for 20 + years . Quite worrying.
on 14-06-2024 10:46 AM
Hi @aggiemantis
Please can you add the account number to your Community Profile (under the Private Notes section)
If you have a FTTP order number, can you also add this to your profile.
on 14-06-2024 10:41 AM
Hi @Debbie-TalkTalk forgive me for butting in but @aggiemantis mentioned an ont box being installed 2 years ago, is that normal for fibre 65?
on 14-06-2024 10:39 AM
I've just checked and information is quite correct.
on 14-06-2024 10:31 AM
Hi aggiemantis
Please can you check the telephone number in your Community Profile is the right number so I can check the details again.
on 14-06-2024 10:29 AM
And as you can see i am connected fine
on 14-06-2024 10:28 AM
Wow, that's serious LOL. I can quite clearly see the IP issued from tt in the router settings
on 14-06-2024 10:19 AM
Hi aggiemantis
I can't even see an IP address generated.
Do you have any other routers connected in bridge mode?
on 14-06-2024 10:14 AM
Yes, the white light on the router is on. All services are running quite normally.
on 14-06-2024 10:11 AM
Hi @aggiemantis
I can't connect to the router, apologies for this.
Is the white light on the front of the router? Could you try a pin hole reset for ten seconds?
on 14-06-2024 10:06 AM
Yes, TT router up and running as of 10.06
on 14-06-2024 10:02 AM
Hi @aggiemantis
Have you got the TT router connected at the moment? (so we can check the wireless stats)
on 14-06-2024 09:36 AM
Good Morning Michelle, thank you for taking the time to reply. Yes, please feel free to test my connection. I'm sure you will find it all in order.
I'm at the point of returning my new router to the supplier.
I have come to the conclusion that there settings at TT that either need to be changed or my new router does no support some 'additional feature' that is required . The later i cant believe as it a well respected and thought out router.
I think the worst thing was having my routers firmware 'upgraded' without my knowledge. Quite concerning.
Thank you again for your time in replying.
on 14-06-2024 08:36 AM
I'm sorry to hear this. Would you like us to take a look at your wifi connection to see if we can make any recommendations?
on 14-06-2024 08:27 AM
Thank you for a reply. The TT servicei is fibre 65 , I believe. The incoming ONT box on the wall was fitted about 2 years ago I think. Black box with row of 4 green LED's in the top. The tt router is the Sagemcom Fast . Ver FAST 5464-2.T4.
Setup is:
Fibre in to ONT ethernet out to WAN port on router.
Performance of the existing router not great , dropouts , generally poor wi-fi coverage. Hence reason for trying a different brand and hopefully better quality router.
on 13-06-2024 07:28 PM
Hi @aggiemantis I've just read back through the thread and see that I never clearly understood what you tt service is, could you clarify please.
Also the box on the wall when was it fitted?
on 13-06-2024 07:09 PM
Thank you for a reply, the purposes would have been to see if anyone using TP Link products NOT, specifically the AX1800 has actually had any success, as its one of the more respected routers out there. Yes i most certainly searched wide and far for an answer.
on 13-06-2024 03:38 PM
Please don't start another topic, it won't serve any purpose.
Nobody at TalkTalk can support third-party routers, it is simply not possible with the plethora of devices available. But other users have successfully managed to set up their own. Have you tried searching across the community, or more widely on e.g Google?
on 13-06-2024 03:16 PM
Update , I contacted TP Tech support , and they confirmed what I had set should work. So I'm now convinced that it is a setting or issue with talk talk.
Is there anybody using a TP-LINK router with talktalk ?
Might start a new topic with that heading and see if there's a response . Tech support a talktalk don't want to seem to know.
