Sagecom FAST 5364-3.TB weak signal in certain important locations
Cornflakefan
Message 12 of 12
I have been trying to improve my system for many years with very limited success. Due to my mobility and health problems, I have had to have a ring doorbell camera and outdoor key safe installed. Now this problem can no longer be accepted as the doorbell only gets a very weak signal RSSI -85 and often loses connection. I have moved the router to the only location possible to get the strongest signal, and using premium twisted core copper cables to negate signal loss of distance between router and master socket. I urgently need a way to extend the range of my wifi signal so I can let emergency or postal services know how to get my door keys if I am unable to get downstairs to answer the door. My flat is only a 1st floor 2 bedroom so I can not even understand why I should need an extender, but nothing talktalk or myself has done much to improve my wifi. The router is in the front room, my bedroom being the furthest distance also has alexa losing connection often not allowing it to conduct services for me. I tried everything I can think of so would really appreciate if someone could help with this.
regards
Russ
Russ
11 REPLIES 11
Message 1 of 12
Good afternoon,
I can see that this was dispatched yesterday so this should arrive either tomorrow or Thursday.
Message 2 of 12
Hi @Cornflakefan
I will ask TalkTalk to confirm the order status for you now.
Message 3 of 12
Hi @Cornflakefan
When you do receive your Version 2 FAST 266 WiFi booster, please can you follow these extra steps when setting it up:-
Very important. Prior to any attempt to connect the F266 to the router, that router MUST be running firmware V202 as a minimum, not V174 or older.
Then place the F266 near the router & attempt a WPS connection of it to the router as mentioned below. After a successful WPS connection, leave the F266 where it is for 30 mins to allow for firmware updates and then, if stable, it can be turned off & relocated to its desired location.
Message 4 of 12
One was ordered last Friday or Saturday but is still not showing on my orders so I am not sure what is happening
Russ
Message 5 of 12
I'm sorry to hear this. Would you like us to send a wifi extender to see how the connection compares?
Message 6 of 12
Hi @Cornflakefan
You have not offended me in the slightest. If you do want my help at a later date, just let me know.
Message 7 of 12
Edit: screenshots removed as they contained the customer's phone number. Never disclose personal information on a public forum.
Russ
Cornflakefan
Message 8 of 12
Thanks again Keith, I was not trying to belittle you or anything like that. It is just that talktalk is trying something so I do not think it wise to do too many changes at once or if one works you would not know which one. I am still unable to access my talk talk mail account that has never been used, I keep getting black screened or a message like in the screenshot. I am sorry if you took offence at my reply but to be honest I am not very tech minded and you responded so quickly, I thought it would take days or weeks to get a reply. As soon as the planned changes take effect, I will inform you either way.
once again, thanks for the too fast reply😂😂😂 but as a non techy can't handle too many changes at once or I will understand or learn nothing.
Best regards
Russ
Russ
Message 9 of 12
My help is nothing like what Customer Services can deal with. In fact I am often asked to help out on here by the TalkTalk forum support staff with WiFi issues. I can provide help, over & above what TalkTalk (or any ISP) can do. The choice is yours though, you do not have to accept my help.
Cornflakefan
Message 10 of 12
Thanks for the offer Keith, I have had talktalk customer service look into this many times, also they have reset and tweaked my router and I am still getting no improvement. They recently sent a Super mail that yet again showed things you can do to improve wifi and router etc ALL of which have been done many times with no improvement, even offered to send out a new router but I told them they tried that 2 years ago and it made no improvement as that was not the problem
regards
Russ
Russ
Message 11 of 12
Hi @Cornflakefan
Depending on what I find I can put a recommendation into TalkTalk for you to improve your WiFi reception.
