Asus RT AX 57 router Fibre 65
Sam200me1
Message 9 of 9
Can I use this router ASUS Rt Ax 57 instead of my old talktalk router, which I have had for over 5 years. This is because I have problems with using multiple devices and speed lags in spite of having Wi-Fi extenders in the house. Reluctant to move to full fibre as wanted to keep home phone number.
If I can use it instead, how would I set it up?
thank you
8 REPLIES 8
Message 1 of 9
thank you that’s really helpful
Message 2 of 9
According to @Divsec above, you need a modem in addition, to use that ASUS router in a pre-Full Fibre connection.
Even though the Wifi Hub 2 has a modem in it, the modem in it, can't be isolated to use it with that ASUS.
So I don't think you can use that ASUS router with a pre-Full Fibre connection. I think you can use it on its own with a Full Fibre connection.
Bill
Sam200me1
Message 3 of 9
Thank you so much for that. I haven’t bought the ASU’s router yet as I wasn’t sure it would work. Could I still add this as well as the Wi-Fi hub?
thank you
Message 4 of 9
I think it works on both, Full Fibre and pre-Full Fibre, @Sam200me1 .
Since you are not ready for full fibre, you can connect from the Master BT socket to the Broadband socket on the far left on the back of the WIFI HUB 2. And it might work better than your older router.
Aren't you going to use your ASUS router for now?
Billx
Message 5 of 9
thanks I decided to get a second hand talktalk Wi-Fi hub 2 as I thought that would be better than my current probably over 5 year old router!  Now wondering if that only for full fibre?
thanks again
Message 6 of 9
thank you - I’ve bought a second hand talktalk Wi-Fi hub 2 router but not sure if this will work better? Is this hub only for full fibre - and needing a fibre connection box?
I can’t go onto full fibre yet as my contract end date is a way off🙁
Billx
Message 7 of 9
You can still upgrade to Full Fibre and keep your 'home phone number'.
But you might not get that much help from TalkTalk to configure your non-TalkTalk router.
Billx
Divsec
Message 8 of 9
Hi @Sam200me1 a quick check suggests the ASUS is a router only so the modem in your tt device would still be needed.
What model is your existing tt device?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
