Replacement Fast-5364 frequently dropping 2.4 GHz
customer-since-2010
Message 14 of 14
I have three questions please regarding my FAST-5364 router, which frequently drops the 2.4GHz band.  For those interested I include details afterwards.
1) I've read in this community about 'Wi-Fi optimisation being turned off', and it solving issues.  I don't understand what this means, but is is worth a try?
2) If I were to set a timer to switch off the power to the router for 20 mins each night, could this forestall the issue?  I anticipate that this is not advised, but if I went ahead anyway then what time in the night should I avoid (for router updates etc.)?
3) I've read in this community about purchasing a router (e.g. various Asus brands).  As I have FTTC would I need to use the FAST-5364 (or my old HG635) as a 'modem'?  If I were to be upgraded to FTTP would I get a different Talk Talk router anyway?
Thank you.
Background:
I received a replacement FAST-5364 on 22 March in response to my community post the previous day.  I was impressed with the responsiveness of customer service, and the replacement router was rock-solid for 3 weeks.  Unfortunately, since 12 April, it has frequently dropped the 2.4GHz band, requiring a re-boot to fix it.  The 5GHz band remains usable. In some cases the 2.4GHz is still being broadcast, but all devices lose connection and can no longer reconnect.  After a re-boot it sometimes lasts a few days, but mostly it needs fixing daily - the time of day varies (I keep a note). A 20 min reboot or a 30 sec off/on seems to make no difference.
It's especially inconvenient as we have a number of home devices that expect 24/7 access, and if we are away we can't reset the router.
I'm not interested in having the line tested etc, as I went thought all of this with the original FAST-5364, and when I swapped it with an old HG635 the problem went away.  The neighbouring Wi-Fi signals are much lower strength so I don't suspect interference.
13 REPLIES 13
Message 1 of 14
Hi Graham,
You could give the HG635 a try to see how it compares. If you do, please let us know how you get on
Message 2 of 14
Hi Karl,
Thanks for having a go at fixing the router.  It behaved for four days, however I had to reboot it this morning as the 2.4GHz band was , again, unconnectable. It's been said elsewhere that it's probably not a router issue, however I don't have confidence with the FAST-5364, even though its my second unit.  I've already mentioned that my old HG635 works faultlessly - its slow and has insufficient range but I'm minded to swap over to it or buy an alternative.  Any thoughts please?
Thanks,
Graham
Message 3 of 14
I've made some changes here to see if I can improve things for you.  I notice some Wi-Fi coverage issues, a couple of devices using 5Ghz band dropping signal to between -80dBm and -90dBm, but this could be mobile devices moving round the home or towards the end of mobile range.
Lets see if the channel changes and other options have any effect, see if performance improves over the course of the day.
Message 4 of 14
Unfortunately, plugging the router directly into a wall socket had no benefit - the 2.4GHz band went down after 28 hours.
I'm thinking of purchasing my own router, perhaps an Asus. As I have FTTC would I need to use the FAST-5364 (or my old HG635) as a 'modem'?
Message 5 of 14
Morning Graham,
Ok thank you.
customer-since-2010
Message 6 of 14
Hi Chris,
Yes, the router was plugged into an extension lead. I've rejigged things so it's now directly into a wall socket. I'll update the post when its had some runtime.
Thanks,
Graham
Message 7 of 14
Hi Graham,
Sorry, deactivating wifi optimisation isn't an option at the moment. Are you able to test temporarily with the router connected directly to the wall socket just to see if it's causing any interference
Message 8 of 14
Hi Chris,
It probably is on an extension lead with other devices (I can't check until later) - we have very few sockets in that room. Is there a high spec extension lead that I could use?
Regarding deactivating optimisation is it a non-option?
Thanks,
Graham
Message 9 of 14
I'm sorry, we can't deactivate wifi optimisation at the moment. I agree that if you have the same issue with 2 different routers then it's probably not going to be the router. Is the router currently connected to a multi-socket electrical extension lead shared with other devices?
Message 10 of 14
Hi Chris,
Thanks for the offer, however this is already my 2nd router, and given that it worked fine for three weeks I'm unsure about trying a third just now. Can we firstly have a go with deactivating the wifi optimisation please?
Message 11 of 14
OK, we can send another router to test with, would you like us to arrange this?
Message 12 of 14
Hi Chris,
I relocated it to an electrically quieter area some time ago but with no benefit.
Chris-TalkTalk
Message 13 of 14
Hi customer-since-2010,
Switching the router off for 20 minutes each night shouldn't cause a problem in itself but not sure if cutting the power to the router with a timer is the best thing to do on a regular basis.
There doesn't appear to be any local wifi interference at the moment. Is the router situated close to other wireless or electrical equipment that could be causing interference?
