Broadband constantly cuts out
Pat JW
Message 4 of 4
This seems to be a problem with many people. Since switching to fibre last month I am having to switch the router off and on again several times a week. Tonight I tried to join a Zoom meeting and found my speed was only 0.5mps! Switched router off and back on and it was 57mps and I could join the meeting. The broadband connection switches off several times a week. Please can I try a new router?
PatJW
3 REPLIES 3
Message 1 of 4
Hi Pat,
I'm sorry to hear this. I've run a test on the line now which hasn't detected a fault and the sync speed looks consistent. Just to confirm, does this also happen if you connect wired?
Message 2 of 4
Tried all that before. Absolute nightmare since switching to fibre. Have updated my profile.
PatJW
Skynet_TX
Message 3 of 4
Hi @Pat JW,
It would be worth going to the Service Centre to ‘Run a live connection test’ on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there, that would then eliminate any of the phone wiring in your home as being a possible cause of the problem.
Then they will hopefully be able to respond to this post within a working day or two.
