Broadband dropping frequently
knightsfield
Message 44 of 44
My broadband connection has been dropping frequently over the last couple of days.
I ran an online connection test, which looked to indicate there was a fault. But looking at the status today it's not obvious if there is a fault or not.
Yesterday it reported: We’re unable to identify a fault on your line.
Today the latest status is: This fault is still in progress. We are working to get this resolved for you
Still having multiple disconnects. So is the fault still being investigated?
Rob
43 REPLIES 43
Message 41 of 44
I have a Openreach master socket 5c which the router plugs into without a filter.
There is no noise on the voice service.
Rob
Message 42 of 44
I'm sorry to hear this. I've run a test on the line now which has detected a potential fault. Is there any noise on the voice service? Does your main socket have a test socket please? If it does then please can you connect the microfilter and router directly at the test socket and we can then re-run the line test.
Gliwmaeden2
Message 43 of 44
My Connection sometimes gives confusing fault tickets, so a good idea to follow up on here, @knightsfield.
Leave the router on, and staff can check your line. They are sometimes at work before normal breakfast time.
Check back later in the morning for a response.
