Broadband dropping frequently
knightsfield
Message 44 of 44
My broadband connection has been dropping frequently over the last couple of days.
I ran an online connection test, which looked to indicate there was a fault. But looking at the status today it's not obvious if there is a fault or not.
Yesterday it reported: We’re unable to identify a fault on your line.
Today the latest status is: This fault is still in progress. We are working to get this resolved for you
Still having multiple disconnects. So is the fault still being investigated?
Rob
43 REPLIES 43
Message 21 of 44
OK thanks. I've just run another line test and it's now passing, not picking up any faults, sync speed is 46.9Mbps and no disconnections showing for the last 7 days, do you still want to go ahead with the engineer visit?
Message 22 of 44
Replied with info on PM
Message 23 of 44
Hi Rob,
If you'd like us to arrange an engineer visit can you confirm:
  • Confirm your mobile number
Message 24 of 44
Stability is a lot better but Speedwise it's still lower than I've had in the past.
Could you look to arrange an engineer visit.
Rob
Message 25 of 44
Hi Rob
How's the connection been? Would you like us to arrange an engineer visit?
Message 26 of 44
Hi Rob,
Next option is to arrange for an engineer for you. Would you like to progress with this now ?
Message 27 of 44
Yes it's connect to the test socket.
Rob
Message 28 of 44
Hi Rob
I've checked the connection stats again this morning and the connection appears to be more stable but the line test is detecting a potential fault towards the property.
Is the replacement router connected at the test socket at the moment?
Message 29 of 44
Hi Rob
Thanks for confirming that the new router is connected.
Please can you leave this router switched on without being rebooted and I will check the connection stats again in 24hrs to see if the connection has remained stable and if the sync speed has started to increase.
Message 30 of 44
I received the new router and just managed to install it. It's connected to the test socket using the supplied filter.
Prior to switching over I was still getting disconnects but not as frequent as before.
Speedwise the router reports syncing at 49 down 10 up, which is similar to what the other router reported.
I'm not sure what sync speed I was getting before I started getting disconnects, but in the past I used to get high 60+ Mbps download and 17+ Mbps upload reported by speedtest.net
Rob
Message 31 of 44
How are you getting on?
Message 32 of 44
Hi Rob
Let us know how the connection compares with this router. We can also run another line test once the new router is connected.
Thanks again.
Message 33 of 44
Yes that would be fine.
Rob
Message 34 of 44
Hi Rob
Are you happy for me to send a replacement router now so we can rule it out?
Message 35 of 44
I think it was a few years ago I was sent a replacement router.
Rob
Message 36 of 44
Hi knightsfield
Thanks for confirming that the router is at the test socket. The line test is detecting the same fault.
Have we recently sent you a replacement router? The next step following this will be an Openreach engineer visit to the property.
Thanks again.
Message 37 of 44
I've managed to find a filter and now have the router connected to the test socket.
Message 38 of 44
Yes a microfilter would need to be connected to the test socket to connect the router. If you don't have one then we can send one to you.
Message 39 of 44
It's not. If I take the faceplate off then it only has a single standard telephone connector. Would I need to then use a filter so I can plug the router in? Not sure I would have a filter available to test with.
Rob
Message 40 of 44
Thanks for confirming. Is the router connected to the test socket behind the faceplate?
