on 23-02-2025 04:23 PM
I've noticed that my internet connection is dropping more frequently than usual. It seems to have coincided with neighbours getting full fibre but may be a coincidence (or a sinister push towards selling it to me). Can someone please check?
Jamie
on 26-05-2025 08:29 AM
Noted, we are sorry for any inconvenience caused, is there anything else you would like me to assist you with at the moment?
26-05-2025 08:22 AM - edited 26-05-2025 08:26 AM
Yes, but as I said it's too late now because I'm having full fibre installed tomorrow.
I spoke with an Openreach engineer outside my property who said the reason my sync speed is low is there will be a High Resistance fault on the line caused by trees across the road, which may not have been picked up on your fault checker. So there appears to be a support gap for customers who experience the same type of fault. They are basically forced to answer irrelevant questions about WiFi coverage and jump through hoops to no avail, all the while the customer isn't to blame and a resolution is never found because of the refusal to send an engineer.
on 26-05-2025 08:12 AM
Hi there, please confirm if you are still experiencing the issue?
on 24-05-2025 08:21 AM
The replacement router eventually arrived, but it didn't improve the situation. Connected directly to the new filter you sent previously, in to the test socket.
Poor speed for weeks through no fault of my own, TT were unable to find the problem less do anything about it. Way under guaranteed speeds but this "guarantee" means nothing, no compensation can be had because of it.
It's too late to do anything about it now, the FTTP installation is Tuesday.
on 19-05-2025 12:49 PM
Yes of course
on 19-05-2025 12:48 PM
I will check for the tracking number on my end as this will help us track the router. I will need to send a private message as we cannot discuss some important information publicly, is that okay with you?
-Fez.
on 19-05-2025 12:39 PM
I'm referring to the replacement router delivery. I'd like to know when it's going to arrive.
on 19-05-2025 12:16 PM
Hi @jamieburchell , we will have this checked for you, are you referring to the order tracking number?
-Fez.
on 19-05-2025 12:15 PM
Is there a tracking number for this delivery @sabelo-TT ?
on 13-05-2025 10:43 AM
Thank you for contacting us, should you need anything else, please feel welcome to reach out to us and we will be here to support you. Have yourself a lovely day.
-Fez.
on 13-05-2025 10:39 AM
No, thank you.
on 13-05-2025 09:21 AM
Pleasure. Apart from what we have discussed, would there be anything else you would like for me to further assist you with today?
on 13-05-2025 08:54 AM
Thank you. I won't need the returns bag - I only have my own router here.
on 13-05-2025 08:46 AM
@jamieburchell not a problem as I have just ordered the replacement router which will be delivered to you within the next 2-3working days. Should there be any delays with the delivery, this will take within 3-5working days for the equipment to be delivered to your home.
In addition, I have included a returns bag for you to kindly return the router you have at your possession.
on 13-05-2025 08:40 AM
on 13-05-2025 08:10 AM
@jamieburchell, hello there. We can still go about the router replacement option as the engineer will not find any fault on your line.
13-05-2025 07:52 AM - edited 13-05-2025 07:56 AM
Right, I have changed my mind. My line is unstable, I've had lots of resyncs this morning and I've had enough. I'm also paying for a service that I'm not getting. I refuse to believe there is no line problem - please send an engineer.
more errors
errors
speed
on 12-05-2025 01:54 PM
Not a problem @jamieburchell 🙂
on 12-05-2025 01:53 PM
Correct. I'll just wait until FTTP is installed.
on 12-05-2025 01:46 PM
I hear your concerns @jamieburchell,
So, by saying this, you prefer me not sending over the replacement router. Correct?
