More frequent disconnections recently
jamieburchell
Super Duper Contributor
Message 150 of 150
I've noticed that my internet connection is dropping more frequently than usual. It seems to have coincided with neighbours getting full fibre but may be a coincidence (or a sinister push towards selling it to me). Can someone please check?
Jamie
149 REPLIES 149
jamieburchell
Message 21 of 150
I am using my own router. I understand you want me to test with yours, but I need specific functionality such as VPN that my router has setup and using another router will disrupt my work.
If you are unable to send an engineer, then it's probably best to just forget about it until they come to install FTTP.
Message 22 of 150
Thank you for this as I do understand. Upon further checking on my end, I noticed that you are currently in use of our Super router while contracted to pour Fibre 65 plan. In this instance, I would like to order a replacement router and once this arrives, I will strongly ask for you to monitor your connection just to check if you would still be experiencing the same issue. 🙂
jamieburchell
Message 23 of 150
I have arranged an upgrade to FTTP, but this will not be installed for another couple of weeks.
Message 24 of 150
@jamieburchell, thank you for this as I do apologise for any difficulties caused.
Upon further investigation, I noticed that a resolution was provided to this matter on your complaint case today. Correct?
jamieburchell
Message 25 of 150
Hi @sabelo-TT
Yes, I'm still capped at around 7Mbps.
Message 26 of 150
Hello there @jamieburchell, just checking to see if you are still affected by internet issues. Kindly confirm with feedback once you have received this message.
jamieburchell
Message 27 of 150
Raising a complaint was a waste of time. The operator started by sympathising about how incredibly frustrating it must be to be asked irrelevant questions about WiFi when I'm using wired ethernet, then proceeded to ask the exact same questions about WiFi. When challenged, they informed me that they were trying to establish where in the house my WiFi was weak. Incredible but not surprising. I guess this is the tier one script.
For the sake of my own sanity, I'm just going to pray that DLM is more effective than support is.
Message 28 of 150
You can find a Complaints link at the bottom of every page.
jamieburchell
Message 29 of 150
How can I raise a complaint please? I'm not getting anywhere here - going around in circles trying to explain to support staff (again) that questions about WiFi are irrelevant because I'm using wired ethernet. Still - where in the house are you using WiFi.
Please can we deviate from the script and apply some intelligence? Seriously frustrating.
Why is it that it's always assumed that the client equipment is to blame anyway? It's been sat there happily connected at 40mbps for months, now I'm capped by DLM at 8mbps. It's Openreach outside up and down the poles and in the cabinets installing FTTP and changing stuff, not me.
jamieburchell
Message 30 of 150
Yes
Message 31 of 150
Thank you, just to confirm are you messaging us from home?
jamieburchell
Message 32 of 150
Hi @amahle-TT I have checked and my profile details are already correct.
Message 33 of 150
Hi there @jamieburchell, can you please register/update your details on your community profile such as account number and/ landline number so I can be able to gain access to your account, look into this for you and run further checks, thanks.
jamieburchell
Message 34 of 150
I have tried directly in the test socket, I have tried directly in the test socket with a filter, I have tried with just the pass-thru faceplate to the test socket. No difference in sync speed, SNR or errors. DLM is capping me at 8Mbps. I guess I'm just stuck waiting until the cap is removed.
I tried reaching out to TT support yesterday, they ran a few line tests but didn't say either way if there was a problem. The conversation then went to "have you changed your WiFi SSD password recently" and at that point I knew I was just wasting my time. That's why I come here - shame that the people that are able to resolve things are no longer around.
Hey ho.
Message 35 of 150
Indeed, but that can fail, hence my suggestion. It will just help to rule an issue out, one way or another.  🙂
jamieburchell
Message 36 of 150
I'll connect to the test socket, with a filter too, overnight and see if it makes any difference. I don't have the original TT router to test with. However, AFAIK I am practically already connected to the test socket - there is a small faceplate (no components) that passes straight through to it attached to the front of the socket to make it look less ugly.
Message 37 of 150
I don't doubt that, this is just another way to check if any part of your internal setup is at fault. Have you tried the FritzBox at the test socket? It may also be better from the support team's point of view if you tested with a TalkTalk router rather than a third-party one.
jamieburchell
Message 38 of 150
I have a BT to RJ11 cable, comes with the FritzBox, so yes I can plug it in directly. In this thread Debbie tells me that I can buy the faceplate from Amazon to make it look neater than connecting to the test socket all the time and without a filter, so I'm getting conflicting information.
Either way, I was running at 40mbps+ with my current setup without a filter since March.
Message 39 of 150
Yes. Apart from anything else, the test socket won't take a DSL cable directly.
jamieburchell
Message 40 of 150
The faceplate doesn't have a filter in it, and I don't use a separate filter. I don't use a telephone. Do I need to use a filter?
