09-12-2024 12:40 PM - edited 09-12-2024 12:42 PM
I have now noticed that since the past few weeks the Hub keeps disconnecting me no matter whether via wifi or wired in and from any computer or mobile. I did reset the Hub and then was okay for few days now starting again.
You can see a lot of latency also and packets drops
Also before this started to happen my ping was at a steady 5ms now is all over the place even when is not disconnecting ping average has gone up from 5 to 9ms
Reply from 151.101.0.81: bytes=32 time=10ms TTL=58
Reply from 151.101.0.81: bytes=32 time=15ms TTL=58
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=8ms TTL=58
Reply from 151.101.0.81: bytes=32 time=29ms TTL=58
Request timed out.
Reply from 151.101.0.81: bytes=32 time=9ms TTL=58
Reply from 151.101.0.81: bytes=32 time=7ms TTL=58
Request timed out.
Reply from 151.101.0.81: bytes=32 time=11ms TTL=58
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=12ms TTL=58
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=5ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=6ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=4ms TTL=58
Reply from 151.101.0.81: bytes=32 time=14ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
on 30-07-2025 04:23 PM
@compu, not at all. 🙂
on 30-07-2025 03:10 PM
I never received anything and it's okay as I bought one off ebay but I want to return this to you guys in the prepaid envelope but I lost the power supply of it, is this going to be a problem?
on 29-01-2025 11:54 AM
I can see the request to send a router was rejected.
I've followed a manual process to request our logistics teams dispatch a router to you.
on 29-01-2025 09:41 AM
Hi Chris
Do you see if the Router has been sent now? I still have received nothing.
I am going to open another post on the Full Fiber section as I thought you guys would have been able to help on that too as I signed up for that but I am only getting messages saying that there are problems and then nothing is explained as to what the problem is.
on 23-01-2025 09:36 AM
I can't see any indication that the hub has been sent yet so I've ordered another, it should be with you within a couple of working days, apologies for the delay
on 22-01-2025 06:16 PM
Hi Chris
No and it does not look like is going to happen for sometime as per BT Openreach delays
Can you let me know if the HUB has been sent as this is defective beside the line still kicking me out.
on 22-01-2025 01:40 PM
Hi compu,
Has your full fibre service been installed now?
on 21-01-2025 07:38 PM
Hi Michelle
Nothing arrived and even the line gets disconnected, I am still connected to the test socket, this happened just now
on 13-01-2025 01:21 PM
Good afternoon,
How are you getting on? Has the replacement router arrived yet?
on 10-01-2025 06:51 AM
No problem. I'll check back in with you on Monday afternoon to see how you're getting on. Have a great weekend.
on 09-01-2025 04:01 PM
Thanks Michelle
Really appreciate
on 09-01-2025 12:51 PM
Good afternoon,
Ok. There is a Wifi Hub on the way now to see how this compares and to rule this out. It should arrive in the next 48hrs.
on 09-01-2025 11:35 AM
Hi Michelle,
If you are referring to the eeero pro I wont use it as not of use for me (no wifi needed) I need all network ports available and rather keep the Wifi Hub but that needs replacement as is constantly kicking me out of LAN and Wifi.
We are looking at few weeks before I even get Openreach to come around.
on 09-01-2025 08:20 AM
Ok thanks for confirming. It's possible that you might be sent a different router. We'll check in a few days to see if we can see if a new router has been sent for you. How often would you say that your connection is dropping at the moment?
on 09-01-2025 07:30 AM
Yes although switched off with rest of the apartment. Just signed up yesterday so it will probably be few weeks.
on 09-01-2025 07:03 AM
Are you currently using the wifi hub? When do you go live on full fibre please?
08-01-2025 05:37 PM - edited 08-01-2025 11:36 PM
Hi Michelle
It has done it few times and sometime also noticed that Router is not rebooting or disconnecting from the line as the light is not changing, steady orange so I think it has to do with the LAN been disconnected, this also affected Wifi.
I am now in the process of upgrading to Full Fiber 150, and I would like the Hub to be replaced as I intend to use this one as wont need or use the eero 6 as will be limitative for me.
Could you please help with this as beside the upgrade the router is disconnecting from LAN and Wifi often, I have already reset the router twice.
on 30-12-2024 09:26 AM
Just checking back in to see how your connection has been over the last few days?
on 24-12-2024 11:04 AM
You too Chris and everyone.
on 24-12-2024 10:23 AM
OK thanks, have a great Christmas 🙂
