Frequent disconnections
compu
Private Message TalkTalk PLUS
Message 48 of 48
I have now noticed that since the past few weeks the Hub keeps disconnecting me no matter whether via wifi or wired in and from any computer or mobile. I did reset the Hub and then was okay for few days now starting again.
You can see a lot of latency also and packets drops
Also before this started to happen my ping was at a steady 5ms now is all over the place even when is not disconnecting ping average has gone up from 5 to 9ms
Reply from 151.101.0.81: bytes=32 time=10ms TTL=58
Reply from 151.101.0.81: bytes=32 time=15ms TTL=58
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=8ms TTL=58
Reply from 151.101.0.81: bytes=32 time=29ms TTL=58
Request timed out.
Reply from 151.101.0.81: bytes=32 time=9ms TTL=58
Reply from 151.101.0.81: bytes=32 time=7ms TTL=58
Request timed out.
Reply from 151.101.0.81: bytes=32 time=11ms TTL=58
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=12ms TTL=58
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=5ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=6ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 151.101.0.81: bytes=32 time=4ms TTL=58
Reply from 151.101.0.81: bytes=32 time=14ms TTL=58
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
47 REPLIES 47
Message 41 of 48
HI @compu
The same fault has been detected on the line tests. Did you also connect the router directly at the test socket?
Message 42 of 48
Hi @compu
I'm just running another line test now and I will post back shortly.
Message 43 of 48
HI Debbie
It is now
Message 44 of 48
Message 45 of 48
Hi Debbie
When you checked the router was probably off as I had to turn it off and use my mobile data to continue work.
Message 46 of 48
Hi @compu
I've completed a line test and it has detected a potential fault. Is the router currently connected at the test socket?
Message 47 of 48
Which WiFi Hub do you have (make/model) and what happens to the status light when this happens?
