More frequent disconnections recently
jamieburchell
Super Duper Contributor
Message 141 of 141
I've noticed that my internet connection is dropping more frequently than usual. It seems to have coincided with neighbours getting full fibre but may be a coincidence (or a sinister push towards selling it to me). Can someone please check?
Jamie
140 REPLIES 140
jamieburchell
Message 101 of 141
Hi @Debbie-TalkTalk
I can't really at the moment (I work from home). I could probably do it just after 3pm.
Message 102 of 141
Hi @jamieburchell
The line test is detecting a loop fault.
Could you remove everything from the line again for 15 minutes?
Message 103 of 141
Hi @jamieburchell
Let me try the other line test first, in your current set up.
I will post back shortly.
Message 104 of 141
Hi @Debbie-TalkTalk
No disconnections or issues since connecting the filter. Same reduced sync speed of 34.2MBits/s. Do you want me to try without the filter to see if there's a detected fault?
Message 105 of 141
Hi @jamieburchell
I've re-checked your connection stats now and the connection looks stable for 48hrs. Is everything still ok?
jamieburchell
Message 107 of 141
Sure, no problem 🙂
Message 108 of 141
Hi @jamieburchell
Ok, please can you keep the router powered up without rebooting and I will check the connection stats again on Wednesday.
jamieburchell
Message 109 of 141
 I haven't run any speed tests - I was referring to the sync speed on the DSL info page of the router, which is usually 40+mbps. Since the disconnections last month it has reduced and stayed at around 34Mbps. It's not noticeable, but my concern combined with the disconnections that were happening was that there's an issue. Happy to keep the filter connected, but as it stands nothing has changed in terms of sync speed or disconnections.
Edit: DSLAM has throttled the downstream throughput to 35Mbps (probably due to the disconnections). Attainable is still ~49Mbps.
Message 110 of 141
Hi @jamieburchell
It's possible the fault cleared. What speed are you now receiving when running speed tests?
jamieburchell
Message 111 of 141
I haven't had a disconnection since 25/02, so it has already been "stable" since then - just at a slower sync speed.
Perhaps the fault cleared irrespective of the filter?
Message 112 of 141
Hi @jamieburchell
Thank you 🙂
The line test is now clear, no faults detected.
Would it be ok to monitor the connection over the next 24hrs and let us know how it compares?
jamieburchell
Message 113 of 141
I have connected the filter
Message 114 of 141
Hi @jamieburchell
Please can you connect the new microfilter and we can run another line test.
jamieburchell
Message 115 of 141
It arrived. Do you want to run a test before I install it, to confirm there's a fault?
Message 116 of 141
Hi @jamieburchell
How are you getting on, did you receive the microfilter?
Message 117 of 141
Hi Jamie,
Thanks for the update. We'll check back in with you on Monday.
jamieburchell
Message 118 of 141
I received an email from Royal Mail this morning to say it will be delivered Saturday (tomorrow).
Jamie
Message 119 of 141
Hi jamie,
Has the microfilter arrived?
Message 120 of 141
Hi jamie,
I'll check back in with you in a couple of days.
