More frequent disconnections recently
jamieburchell
Super Duper Contributor
Message 141 of 141
I've noticed that my internet connection is dropping more frequently than usual. It seems to have coincided with neighbours getting full fibre but may be a coincidence (or a sinister push towards selling it to me). Can someone please check?
Jamie
140 REPLIES 140
Message 121 of 141
Thank you
Message 122 of 141
I've ordered a micro-filter, it should be with you within a couple of working days
jamieburchell
Message 123 of 141
Sure no problem. Thanks.
Message 124 of 141
Hi jamie,
Ok, we can send a microfilter out to you, would this be ok? It's just so we can rule out any potential issues with the faceplate causing the loop fault.
jamieburchell
Message 125 of 141
It's the only socket in the home. There is no extension wiring.
I don't have a microfilter to test with.
Message 126 of 141
Hi jamie,
The 5C main socket should have a test socket below the faceplate. Would it be possible to gently lift away the front faceplate (there may be wires attached to the back) and connect the microfilter and router at the test socket so I can re-run the line test again please?
Message 127 of 141
Is that the only telephone socket in your home?
jamieburchell
Message 128 of 141
Master Socket 5C MK4Master Socket 5C MK4
Message 129 of 141
Hi jamie,
Thanks for the update. The line test is now detecting a loop fault. Can I just check, which main socket do you have please?
Your guide to main phone sockets - TalkTalk Help & Support
jamieburchell
Message 130 of 141
Thanks. I haven't had a disconnection since 23rd so I'll come back if this situation gets worse. My speed has gone from the usual 40Mbit/s to 34.2Mbit/s though.
Message 131 of 141
Yes it could affect the broadband service, that why we ask you to check the voice as noise on the line can cause disconnections
jamieburchell
Message 132 of 141
Ah, OK. Could the affect the broadband connection? I don't really care about the voice side.
Message 133 of 141
The broadband line test passed, no fault found, but did say 'voice fault suspected'. We can arrange an engineer visit to investigate. If you'd like us to do this please let us know and we'll confirm some details with you
jamieburchell
Message 134 of 141
I do not. I'm confused- is there a fault with the line or?
Message 135 of 141
Hi Jamie,
Do you have a TalkTalk router that you can test with?
Message 136 of 141
We only have one (master) socket and it's still connected to that. We don't have any extension wiring.
Here's the connection logs from the router (FritzBox 7590) for the past few days.
23.02.25 16:15:43 DSL not responding (no DSL synchronization).
23.02.25 01:46:23 DSL not responding (no DSL synchronization).
22.02.25 18:55:55 DSL not responding (no DSL synchronization).
22.02.25 18:41:58 DSL not responding (no DSL synchronization).
22.02.25 18:32:50 DSL not responding (no DSL synchronization).
21.02.25 20:11:54 DSL not responding (no DSL synchronization).
21.02.25 20:07:56 DSL not responding (no DSL synchronization).
20.02.25 19:28:59 DSL not responding (no DSL synchronization).
20.02.25 19:23:20 DSL not responding (no DSL synchronization).
19.02.25 08:09:02 DSL not responding (no DSL synchronization).
Message 137 of 141
Hi @jamieburchell
Is your router currently connected at the test socket?
jamieburchell
Message 138 of 141
We don't use the landline for calls anymore.  I have an automated voicemail on it to this effect if you do call it.
Message 139 of 141
Hi @jamieburchell
I've completed a line test and this has detected a possible issue with the landline service.
Do you use the line for making calls?
Message 140 of 141
2. What package are you on?
3. What is the exact status of the lights on the front of the router when this happens?
4. If you have any wired connections, are they affected in the same way as wireless ones?
