Connecting to new P.C.
stevePG
Message 7 of 7
I've got an old Fujitsu AMILO Desktop Pi 3635, that I'm trying to re-use after cleaning everything on it and a system recover. How do I connect to wi-fi, I'm using B.T. extender and ethernet cable. It won't connect. Please help.
Steve
6 REPLIES 6
Message 1 of 7
Just a suggestion, You could try using a USB WiFi dongle if the pc has a port available,  they are fairly cheap on ebay
Ready to learn something new today
Message 2 of 7
Hi Steve,
I don't know to be honest. I think Microsoft stopped providing support for Windows a few years ago, it's probably not getting security updates now
Message 3 of 7
Hi again Chris, since your chat this a.m. I have done another complete system recovery. It tells me to "install wireless networking hardware & verify that the correct drivers are loaded". It is now re-set to Windows Vista Home Premium. Is it possible to download on another computer to disc and then load onto the Fujitsu one? If so where would I find it. Many thanks in anticipation.                                                  Steve.
Message 4 of 7
OK thanks Steve. Does the PC definitely have a wireless card (wireless capable)? Which version of Windows is it running?
Message 5 of 7
Thanks for replying. I want to connect to the internet. The P.C. doesn't pick up any nearby routers to show when I try to log on to anything. There isn't a symbol bottom right to indicate for me to click on to show nearby routers.
Steve.
Chris-TalkTalk
Message 6 of 7
Hi Steve,
When you say wifi do you mean that you're trying to connect to the router by wifi or are you referring to the Internet connection in general?
