Yale alarm and Eero 6
FrustratedUser123
Message 6 of 6
Hi, I'm having issues witth my yale smart alarm and eero 6
After trawling many posts it seems that the security in eero needs to be disabled in order to get the Yale home alarm to work. However there is no option to disable it in the app anymore (June 2023)
How can this be resolved, had a very handy email from Talktalk asking me to post here rather than trying to resolve the issue.
Also, the single ethernet port on the eero 6 is pretty useless for our home now. There was no issues with the previous router, can this just be used instead so we can have our 4 ethernet ports back?
All very frustrating, if talktalk could respond that would be great, as finding their livechat link is all but impossible with loops just sending you back to the beginning of the search..
5 REPLIES 5
Message 1 of 6
Hi MarkaP
As you will see from this topic you can disable eero Secure in the eero app to enable a custom DNS. Try the Google DNS 8.8.8.8 and the Yale device will connect as confirmed by user reports.
If you still have an issue then start your own topic.
MarkaP
Message 2 of 6
Hi. Did you resolve this problem? I'm in the same position.  Cheers
Anonymous User
Message 3 of 6
How are you getting on?
Gondola
Message 4 of 6
You can use a Wi-Fi Hub in place of the eero 6 if you wish. Or connect a 5 port GB network switch to the available GB Ethernet port on the eero.
Eero Secure is now renamed by Amazon as eero Plus. To use a custom DNS to get your Yale system to work does require eero Plus to be switched off and all related blocking features disabled. Via the Discover tab switch off Advanced Security, Ad Blocking, all Content filters, app blocking and website blocking.
You'll then see via the Settings tab that a Custom DNS is available.
Message 5 of 6
You can use the router if you need more ethernet ports.  You should have an option in the app to contact EERO support for assistance with the security settings.
Anonymous User
