on 06-12-2025 09:50 PM
This evening, my router (TP-Link Archer VR2100) disconnected and reconnected at least half a dozen times over the course of about 90 minutes. Each time it was increasingly slow in terms of sync speed and is currently syncing at 25949 when it should be 40000 plus.
Nothing has changed, either with hardware, cabling or location and it looked very much like a fault on the line.
Any help would be appreciated.
on 17-12-2025 12:33 PM
just to confirm you were referring to the Wi-Fi hub?
on 17-12-2025 12:25 PM
My apologies. It was the wifi hub I connected.
on 17-12-2025 12:17 PM
I can see that a Wi-Fi hub was sent last year, can you please use that router not the super router.
on 17-12-2025 12:15 PM
Thank you. Ill look at that.
Back to my router issue. I connected the talktalk super router but it simply looped through connecting and disconnecting. Did it about 5 times before I gave up. Don't think there's anything wrong with the power supply because I was able to log into the router whilst it was offline and I input 4 static IP addresses without it rebooting. So; I'm back with the TP-Link Archer and its syncing at around 32K
on 17-12-2025 11:26 AM
Verify SMTP Settings: Go to your account settings in Outlook and double-check the SMTP settings.
Test Connectivity: Use a webmail interface to send an email from your TalkTalk account, if available. This checks if the problem lies in Outlook or the email server itself.
Clear Outlook Cache: Sometimes clearing the cache can resolve issues. Exit Outlook and delete the cache files.
Update Outlook: Ensure that your Outlook application is up to date.
Contact Support: If the issue persists, contacting TalkTalk customer support can provide insights specific to your account.
Implement these steps, and you should be able to identify or resolve the issue with sending emails from your TalkTalk account. Let me know if you need more specific guidance on any step!
on 17-12-2025 11:25 AM
@philipm you can refer to the link below with FAQS regarding issues with email.
https://community.talktalk.co.uk/t5/Articles/Problems-with-TalkTalk-Mail/ta-p/2204405
on 17-12-2025 11:23 AM
That is a third-party app we will be unable to complete diagnostics. I can only give advice that is general.
on 17-12-2025 11:20 AM
No. I'm using Outlook (Office Pro 2021).
on 17-12-2025 10:30 AM
Are you using webmail to access your emails?
on 17-12-2025 10:24 AM
Whilst I'm doing that; is there any way you can look into my email account? I use Outlook and the talktalk email receives everything just fine. It appears to send things fine too but they don't get received. This has happened several times in the last week or so. I can send from my hotmail address but not my talktalk one. I don't get any bouncebacks though. A bit weird.
on 17-12-2025 10:16 AM
Okay thank you.
OK. I'll try to get hold of a power supply then come back to you.
on 17-12-2025 10:07 AM
The test needs to run a check on the equipment and since it is not a TalkTalk supplied router it will not pick up any fault.
on 17-12-2025 10:05 AM
I don't have a functioning power supply for it but, I guess, I can try to get hold of one.
Are you not able to test the line - everything external to the router?
on 17-12-2025 10:02 AM
@philipm I will not be able to run a diagnostics test with a router that is not supplied by TalkTalk, can you please plug it in if possible and check the stability.
on 17-12-2025 10:00 AM
No. I'm using a TP-Link router that I have had for months and months. It gives me a mesh system that my talktalk supplied router can't.
on 17-12-2025 09:54 AM
Just to confirm, are you using the router that has been supplied by TalkTalk?
on 17-12-2025 09:52 AM
Yes. I am
on 17-12-2025 09:40 AM
Hi @philipm are you currently at home for diagnostics test?
on 17-12-2025 09:38 AM
Back to where we were.
Been syncing, reliably, at around 35k for the last week but, this morning, found that it was syncing at 8k. Turned off the router for half an hour and I am now syncing at 32k. This is still considerably slower than I was used to up to ten days ago.
Something is clearly amiss and with the Christmas break coming up, two people needing top work from home and a house full of other family, I could use something more reliable.
