Dlm reset?
Magicukgs
Message 54 of 54
I’ve read and don’t think it’s possible but I had a new fuse board fitted and the electrician was stopping power and turning back on so loads of stop and staring of the connecting. Use to get 61ish and now down to 50. Not a major issue. Line has been up for 9 days and 22hours. SNR still at 6. Anything I can do or is it a case of waiting only.  Had 60 for years but that was at 3SNR.
53 REPLIES 53
Message 41 of 54
Thank you for confirming, we now need to capture the make and model of your router. This can be found on the back or underneath your router. Can you provide me with this please?
Magicukgs
Message 42 of 54
Yes have mobile
Message 43 of 54
Will you and anyone who lives with you be able to contact emergency services while your service remain impacted.
Message 44 of 54
No no issues with any of them.
Message 45 of 54
Thank you for confirming, I'm just going to run through some questions with you as part of the line tests that I am conducting, do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example, a care alarm, lifeline, health pendant or fall detector.
Magicukgs
Message 46 of 54
Yes
Message 47 of 54
Just to confirm, Are you currently at home, where the TalkTalk service is installed?
Message 48 of 54
@Magicukgs please allow us time to look into this. I will run few tests on my end to determine how this can be improved. Thanks
Message 49 of 54
No speeds are fine but my dlm snr has gone to 6 which has reduced my sync Is there anything that can be done or just a case of waiting.
Message 50 of 54
Thanks so are you experiencing slow speeds when using your internet?
Message 51 of 54
Message 52 of 54
Hi there Magicukgs. Please run a speed test and let me know what speeds you are getting.
Magicukgs
Message 53 of 54
