EERO 6 RJ-45 Ethernet connections to Desktop computers - not Wi-Fi
MykhailoM
Message 2 of 2
Hi, How on earth one can connect computers by physical cables such as RJ-45 if there is only 1 socket output on the EERO 6 router !?  ( I have 3 PC`s to connect and need both hard -wired and Wi-Fi connections as in my old router)
Thanks !
1 REPLY 1
Message 1 of 2
Just buy a cheap gigabit unmanaged network switch.
