Eero 6 or Hub3
oobimech
Message 5 of 5
I am an existing FF150 customer and have just renewed my contract.  I have been sent a Hub3 router but would prefer to remain using my Eero6 that I got with my initial contract.
Can I do this ?
Am I correct in assuming that the Eero 6 will perform better than the Hub3, bearing in mind that I have an additional Eero in an upstairs room and also 2 echo dots that extend the wifi?
If that's the case, do I just continue as normal with the existing set up?
Many thanks.
4 REPLIES 4
oobimech
Message 1 of 5
Will do.
Message 2 of 5
Give it a try, nothing to lose but your sanity😈
Don't forget to change WiFi passwords in the hub to suit your existing devices
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
oobimech
Message 3 of 5
Yes, TT sent a returns bag but I'm inclined to maybe try the Hub 3 and compare it to the Eero.  I just think I would get better coverage around the house with the Eero.
Divsec
Message 4 of 5
Hi @oobimech yes if it works for you. The hub 3 is the best sagemcom router I've used. Have TT sent you a returns bag?
