on 29-10-2025 08:43 PM
Hi there,
I don't know if this is the right section but I have a weird problem that started earlier today.
I'm using Cyberduck FTP software to connect to websites on a particular hosting company's servers and it's been working fine for years. Suddenly I now have an issue where FTP connections fail on this particular host.
If I switch my Mac to use 4G the FTP connection works fine but once switched back to WiFi it refuses to connect again. Occasionally the problem rights itself and then stops working again.
Other FTP connections to different hosting companies work perfectly over WiFi. The host I'm experiencing issues with checked all my connection details and they are correct and as I mentioned are working using a 4G connection.
Where do I even start to fix this? Thanks for you assistance.
John.
on 10-11-2025 07:03 AM
Thank you @KeithFrench
on 03-11-2025 11:40 AM
Hi @joh42mar
Maybe, if it recurs, then I will need to see the log from your FTP client and ideally a Wireshark trace. Is your client using Secure FTP or just FTP? Please PM them to me to preserve your privacy.
on 03-11-2025 11:25 AM
Thanks Keith. It looks like the problem has cleared up. Maybe it was just a temporary glitch?
on 02-11-2025 11:37 AM
Hi @joh42mar
To find out why your FTP client cannot connect to this FTP server, does the client have any FTP logs on your PC? If so, please can you PM them to me (to protect your privacy)? Failing that, the only way to identify the problem is for you to install Wireshark and capture the failed connection attempt for me. I can provide full details of how to do this.
on 30-10-2025 10:34 AM
We are currently investigating this, can you please try using another device at the moment, thanks.
on 30-10-2025 10:27 AM
I'm not trying to access a website, I'm trying to upload files to an FTP server.
30-10-2025 10:26 AM - edited 30-10-2025 10:26 AM
What is the full address of the website you're trying to access?
on 30-10-2025 10:23 AM
No, but the issue isn't being able to view a website, it's a problem FTPing files to my hosts server.
on 30-10-2025 10:22 AM
Do you see a blocked webpage notification message when attempting to access the site you experience problems with?
on 30-10-2025 10:20 AM
No.
on 30-10-2025 10:19 AM
Thank you for confirming, do you have any active monitoring for life threatening health reasons which is solely dependant upon your TalkTalk Broadband or Telephone line?
For example a care alarm, lifeline, health pendant or fall detector.
on 30-10-2025 10:14 AM
I am but I'm currently using a VPN.
on 30-10-2025 10:13 AM
Okay no worries. Please confirm if you are messaging us from home.
on 30-10-2025 09:53 AM
I've tried changing the DNS in my Mac's system settings but that didn't work I'm afraid.
on 30-10-2025 07:47 AM
Yes, you can update your DNS settings through the System Preferences on your Mac. Here’s how to do it:
Open System Preferences:
Go to Network:
Select Your Active Network:
Access Advanced Settings:
Navigate to the DNS Tab:
Add Google DNS:
Apply Changes:
After changing the DNS settings, try connecting to your FTP host again using Cyberduck. This may resolve any connectivity issues. If you continue to experience problems, let me know, and we can explore further options. Thanks.
on 30-10-2025 07:46 AM
Thank you. I'm using a Mac so would that be through my system settings?
on 30-10-2025 07:38 AM
Try changing your DNS settings to a public DNS, like Google DNS (8.8.8.8 and 8.8.4.4), to see if that resolves the issue.
on 30-10-2025 07:29 AM
Thanks for getting back to me. I've tried both of those as fixes and neither worked. I've fixed it short term by using a VPN. The issue is intermittent and seemed to start yesterday. I don't know if that info helps at your end.
on 30-10-2025 07:22 AM
Hi there @joh42mar. I am very sorry to hear this. Restart your router to clear any temporary glitches that might be causing the connection issues also ensure that your router's firmware is up to date.
