on 24-03-2025 06:13 PM
Hello.
My ADSL cable that connects my router to my BT data socket is faulty. I have borrowed one to test this and the borrowed one works.
As this cable came with my TalkTalk router, could TalkTalk please send me a replacement ADSL cable (2 metres long with RJ11 male connectors at each end).
Many thanks,
Geoff B
on 01-04-2025 09:19 AM
OK Geoff, if you need any further assistance just let us know
on 01-04-2025 09:16 AM
Hi Chris.
The old TalkTalk cable that failed also had two pins. However, the local computer stores don't seem to sell them anymore (just 4-pin cables instead).
Not to worry, the 4-pin cable I bought the other day works, so I'm back up and running again.
Best wishes,
Geoff
on 31-03-2025 07:43 AM
Hi Geoff,
How many pins does the old TalkTalk cable have?
on 28-03-2025 05:27 PM
Hi Chris.
The new ADSL cable has arrived, but it doesn't seem to work ("no internet connection").
I've now bought another cable from the local computer shop and that works fine.
The only physical difference I can see is that the cable that TalkTalk sent me has only two of the four pins in the RJ11 connectors wired, whereas the one I bought has all four pins wired.
Is it possible that the one TalkTalk just sent me is an older version that somehow won't work these days, or perhaps it was a genuinely faulty cable?
Any advice would be greatly appreciated.
In the meantime, the cable I bought has given me access to the internet once again.
Many thanks for any comments/advice.
Geoff
on 25-03-2025 02:44 PM
No problem 🙂
on 25-03-2025 02:29 PM
Many thanks, Chris.
Geoff
on 25-03-2025 10:02 AM
Hi Geoff,
I've ordered a replacement cable, it should be with you within a couple of working days
on 24-03-2025 07:52 PM
Hi Divsec, thanks for your reply.
I don't know how it became faulty, I'm afraid. There's nothing wrong with the router, just needs a new cable.
Geoff B
on 24-03-2025 06:59 PM
Hi @Geoff_B , your post has been escalated and you should hear soon.
How did the cable become faulty, vacuum cleaner or dog?
Likely outcome will be a replacement router.
