Fibre 35 speed only 17 when the information says 38 mbs available
Violet66
Message 5 of 5
Internet very slow
4 REPLIES 4
Message 1 of 5
Morning Violet,
Are you still experiencing slow speeds?
Chris-TalkTalk
Message 2 of 5
Hi Violet,
If you still need assistance can you please answer Keith's questions and we'll be happy to help
Message 3 of 5
@Violet66
Just to add: 38Mbps is the top speed available for the product. Your actual connection speed will be largely determined by the distance of the copper connection from the fibre cabinet. What guaranteed minimum speed were you advised of at the point of ordering?
Message 4 of 5
2. What is your minimum download speed?
3. If you log into the router, what speeds are shown there (normally in the initial Dashboard area)?
4. If you have any wired connections, are they affected in the same way as wireless ones?
