Router Randomly resets every so often. Attached Log
MariaGoltyakova
Message 6 of 6
Router Info:
Device Type:  DG8041W
CPE Description: EchoLife DG8041W Home Gateway
SN: 2153035991QUL5130706
Hardware Version: l.0.01
Software Version: v1.08t
Log entries that I believe indicate the problem:
2024-02-24 22:56:12 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: [0], Terminal:OTHER
2024-02-25 01:01:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: [0], Terminal:OTHER
As mentioned in the subject line, router keeps resetting itself every so often, no noticeable pattern. Has been doing so for the last couple of weeks.
Please assist.
5 REPLIES 5
Message 1 of 6
Hi Maria,
Just checking back in to see how you're getting on?
Michelle 🙂
Message 2 of 6
Hi MariaGoltyakova
MariaGoltyakova
Message 3 of 6
Yes please go ahead
Message 4 of 6
Hi MariaGoltyakova
I'm really sorry about this.
I will need to send you a different make and model of router (Sagemcom) Are you happy for me to arrange this?
Message 5 of 6
This firmware is known to be unstable, I have asked one of TalkTalk's support to pick your thread up and decide the best way forward.
