Router DG8041W restart kernel panic
skilly28
Message 8 of 8
Router details:
Device Type: DG8041W
Description: EchoLife DG8041W Home Gateway
Hardware Version: I.1.01
Software Version: v1.05t
Router is restarting regularly, sometimes multiple times a day with a kernel panic alarm.
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
Would a firmware update resolve this?
7 REPLIES 7
Message 1 of 8
Hi skilly28
Thanks for letting us know 🙂
If you do experience any further issues then please post back on this thread to let us know.
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
skilly28
Message 2 of 8
Hi Michelle,
The new router arrived today. Thanks for sending it out.
Message 3 of 8
Good morning,
Just checking back in to see if the router has arrived?
Message 4 of 8
Hi skilly28,
I've ordered the replacement router, it should be with you within a couple of days
skilly28
Message 5 of 8
Hi Debbie,
Thanks for your reply.  That would be great if you could arrange it.
Message 6 of 8
Hi skilly28
I'm really sorry about this.
I will need to send you a different make and model of router (Sagemcom WIFI hub) to resolve this issue. Are you happy for me to arrange this?
Message 7 of 8
Possibly, there is a lot of issues with this router's firmware, so I have asked one of TalkTalk's support to pick your thread up and advise on the best way forward.
