3 hours ago
I am currently on Fibre 65 and have two additional Talk Talk WiFi boosters fitted. If I move to Fibre 500 as we now have full Fibre in our area, I appreciate that the router will be EERO 6. Will I still need the boosters and will my old ones work. If not, how much do the new boosters cost. Finally how many ports does the EERO router have.
Any advice will be most appreciated.
Answered! Go to Solution.
3 hours ago
FF500 attracts one eero Pro 6, not an eero 6. If your old boosters are the Sagemcom FAST266, then these will not work. The eero Pro 6 has two Ethernet ports like the eero 6, so one will be used to connect to the ONT. It is impossible to say if you will need a second eero Pro 6 without proving it. If you want a second eero Pro 6, without having proved that you need one, then ask the Loyalty Dept for a price. Alternatively, I can always help to determine the state of the WiFi & that is free.
