Router shows white light but no net
pcupgrade
Message 4 of 4
  • Hi,
My sagemcom router shows white light but there is no internet. The issue is resolved by restarting the router.  But the internet will cut again after a 20-30 minutes and the router will continue to show white light. I have hard reset the router already, left it off for 1/2 hour but still the same outcome.
It was working fine but has become worse over the last few days
any advise would be great
thanks
Pardeep Dade
3 REPLIES 3
Message 1 of 4
Hi pcupgrade,
There are updates about the issue on our service dashboard - Service Status | TalkTalk Help & Support
If you are currently experiencing disconnections could you reboot your router and then monitor to see if the disconnections continue
Message 2 of 4
Thanks for your reply, i thought it may be a faulty router, i started to notice this a few days ago but have had some issues over the past few weeks.
What has caused this issue? is it firmware related?
Pardeep Dade
Message 3 of 4
Good afternoon,
We are aware of this particular fault and our engineers are currently rolling out a fix to resolve this. Can I just ask, when did this last happen please as the fix rollout started this morning?
