on 07-07-2023 11:17 AM
In April 2023 I upgraded to Fibre 65 from Fibre 35.
Recently I have had constant slow-downs and disconnections.
I have twice been through the process of testing my connection and having an Openreach engineer automatically called out.
Each time they have tested the connection and said it was fine - only to have it drop out again later.
I never had any problems with Fibre 35.
When I was switched to Fibre 65 I was not sent a new router.
My current router reports the following device details:
Device Type: DG8041W
Description: EchoLife DG8041W Home Gateway
SN: 2153035991QUKA032150
Hardware Version: I.1.01
Software Version: v1.05t
Is this router suitable for Fibre 65? Could it be faulty?
The LED on the front no longer lights up green when I have a connection.
Also, the last Openreach engineer I spoke to said that there had been a lightning strike on a 'cab' in my area recently.
Apparently, several other people have reported router issues.
Can you suggest a course of action?
Terry
on 07-07-2023 11:29 AM
Hi Terry
No problem 🙂
on 07-07-2023 11:25 AM
Hi Debbie
Thanks for the incredibly quick reply!
Yes - could you send out a replacement?
At least this would allow me to eliminate the router as the cause of the problem.
Many thanks
Terry
07-07-2023 11:21 AM - edited 07-07-2023 11:22 AM
Hi Terry
The line test hasn't detected any faults and the connection appears to be stable.
Would you like me to send a replacement router for testing so we can rule this out?
