Fibre35 is rubbish
Paul#
Message 5 of 5
I have only  ever got 20.8 & 5.15, I was told average should be 38!
Anyone care to comment on how crap their fibre35 is?
4 REPLIES 4
Chris-TalkTalk
Message 1 of 5
Hi Paul,
If you still need assistance can you please update your community profile as Michelle has requested
AllyM
Message 2 of 5
I'm not sure what you mean by "average" speed @Paul# . The maximum possible speeds on the Fibre35 package are 40Mbps download and 10Mbps upload, but the actual speed you will achieve is determined mainly by the quality and length of the copper part of the phone line from your home to the PCP cabinet. The important figure to note is your own personal guaranteed minimum speed of which you should have been advised when you took out your contract.
If you update your information as Michelle has advised, staff will be able to check your line and account details.
It may also help if you could answer Keith's questions regarding how you are testing the speed as WiFi signals can be susceptible to speed reduction due to conditions within your home (location of router, walls, interference etc) which he may be able to offer you some help with if that is your problem.
Message 3 of 5
Hi Paul,
  • Name
  • Telephone number
  • Alternative contact number
Message 4 of 5
You have a problem that needs diagnosing. I assume that those figures are from speed test websites? Please can you elaborate by answering these few questions:-
2. If you log into the router, what speeds does it show there (often in the initial dashboard area)?
3. If you have any wired connections, are they affected in the same way as wireless ones?
