Full Fibre Broadband
Roy5051uk1
Message 5 of 5
I have Fibre35, but it seems I cannot upgrade to Full Fibre.
Is this because of Openreach, or is it just that it is not available at my house?
*removed*
roy5051uk1
4 REPLIES 4
Message 1 of 5
It's not a problem as such, it just it what it is, Openreach appear to have  drawn a line on which you seem to have fallen on the wrong side.  As I said, have a look at the options which are actually available to you, rather than those that are not.
Message 2 of 5
 The problem seems to be that Openreach put broadband on to our estate, but left 5 houses on the end of Southfields BA11 5AN with partial FTTC, which means those 5 houses can only get 35Mbps broadband. Help!
Roy5051uk
Chris-TalkTalk
Message 3 of 5
Hi Roy,
How are you getting on, has you tried the checker as ferguson suggested?
Message 4 of 5
It may be that Openreach do not have a service available, nor one of TalkTalk's other partners. There me be alternative network providers you can check with. Try the Ofcom checker here
I have removed your address details, it is best not to post such information in public.
