Having to hard reset Wi-Fi hub every few hours
DJ_Nicol
Message 5 of 5
My wifi hub has been working fine for several years, but over the past 3-4 days my devices are periodically disconnecting and I am having to hard reset the WiFi hub once or twice a day to get them to reconnect. The router showed a solid white light even when devices won’t connect. However after the latest restart it is just flashing orange (have tried re-restarting a couple of times and leaving on flashing orange for 45 mins)
Set up hasn’t changed and it is affecting multiple devices.
Feels like the router has developed a fault?
4 REPLIES 4
Message 1 of 5
How are you getting on?
Message 2 of 5
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using (the hubs include Sagemcom 5364 or 5464 alternatively there is the Huawei DG8041W)?
Message 3 of 5
Do you still need assistance with this?
Message 4 of 5
Hi DJ_Nicol
I'm sorry to hear this. Would you like me to send a replacement router for testing?
