INTERNET DISCONNECTIONS
Inese3
Message 31 of 31
I have bad wifi on all devices. Have to reboot the router about 10 times a day to connect to wifi but it still keeps disconnecting. It happens for last 3 weeks. We have never had problems before, we've done all the usual tests and service status is "We suspect an issue with your broadband" but fault tracker unable identify a fault. So still experiencing a sudden disconnections and most of the times is no reconnections without rebooting. Can anyone help please? Thank you.
30 REPLIES 30
Inese3
Message 21 of 31
Hello again,
I received a micro-filter today and now have the router connected to the test socket.
Message 22 of 31
No problem, I'll order it now
Message 23 of 31
Yes, please, would be great. Thanks, Chris
Message 24 of 31
OK, I can send a micro-filter to test with, would you like me to arrange this?
Message 25 of 31
Yes
Message 26 of 31
Hi inese3,
Yes you would will need a micro-filter. Is that the only telephone socket you have in your home?
Inese3
Message 27 of 31
Hi Debbie
Sorry for delay. No, we don't use a landline phone. Not sure if I can connect the router directly into the test socket because if I remove the faceplate it only has one standard telephone connector. Do I need a microfilter then? I don't have it..
Message 28 of 31
Hi Inese3
I've completed a line test which has detected a potential fault with the landline service.
Do you use your landline?
Have you connected the router directly at the test socket?
Inese3
Message 29 of 31
I just added.
Thanks Debbie
Message 30 of 31
Hi Inese3
Please can you add your TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Anonymous User
