Internet down
djpurle
Message 22 of 22
I have a Sagem FAST 5364 modem (firmware SG4K100136)  which has happily been providing a robust and heavily used connection over vDSL for many months.
Since 0035 on Sunday morning, I have intermittent DNS and routing issues. Connection to external websites either fails or is extremely slow.
A ping to 8.8.8.8 shows 50% to 100% packet loss.
The problem has persisted for over 30 hours.
I have powered down and disconnected modem for 30mins to restart my session.
I have expected line sync at 80000/20000 and a DHCP connection serving public IP address and DNS servers identified. The modem is showing solid white led.
A Tallktalk connection test indicates I have a healthy connection, which I do not.
I am testing with a wired LAN connection directly onto my modem which is connected to the master Openstream socket. There have been no changes to the setup or cabling.
The modem logs show failure to connect to the TR069 server with DNS look up and “failed to connect” messages.
This does not seem to be an issue with my modem, rather routing/DNS at TalkTalk end.
Please help!
21 REPLIES 21
Message 1 of 22
I'm really glad to hear this and thanks for the update 🙂
Message 2 of 22
Hi Michelle
Internet is very stable and no further issues.
Many thanks to you and the team for your help!
David
Message 3 of 22
Just checking in to see how the connection has been since the FW update?
Message 4 of 22
I've updated the router firmware to V174.
Message 5 of 22
Hi Debbie
Please go ahead.
Message 6 of 22
Hi David
That's great,  thanks for letting us know.
Would you like me to update this router firmware to latest version?
Message 7 of 22
Hi Debbie
The new router has arrived and is now up and running on v136 firmware.
Please note that after the issues over the weekend and support call, the connection came back alive on Monday evening.
I was able to get a borrowed modem connecting as well as my original TalkTalk hub.
I still suspect that there was an external infrastructure issue.
Anyway, normal service is restored.
Many thanks for your help
Message 8 of 22
Hi David
Message 9 of 22
Hi David
Ahh you're very welcome 🙂
Message 10 of 22
Great!
Will get back to you.
Thanks to you and Michelle for your timely responses today.
David
Message 11 of 22
Hi David
No problem.
Let us know once the new router is connected and I will check the firmware on this router.
Message 12 of 22
Thanks Debbie
Yes please
Message 13 of 22
Hi David
Apologies, I still can't connect to the router.
Would you like me to send a replacement router?
Message 14 of 22
Hi Debbie
Router has rebooted and connected (solid white LED).
Please go ahead and see if you can connect/update.
David
Message 15 of 22
Hi David
Thank you. Once the router has been switched back on after the 30 minute power down then please let me know and I will try and connect again.
Message 16 of 22
Hi There
my wife is back home now and has pulled the power on the modem.
shall we wait 30mins to clear session or reboot right away?
Message 17 of 22
Hi David
Apologies, I'm unable to connect to your router to update the firmware, I have tried this a couple of times.
Please can you reset the router when you are home and I can try and connect to your router again.
Message 18 of 22
Hi Michelle
Please go ahead.
I am not at home - can you do this remotely?
David
Message 19 of 22
We can try a new firmware for the router first, would this be ok to do now? It will take about 20 minutes and the router cannot be rebooted or turned off during this period.
djpurle
Message 20 of 22
Hi Michelle
The actually connection of modem to your infrastructure seems solid.
The packet loss seems to be cause of the poor and unstable internet.
Are there any logs I can access from the modem to help?
Unfortunately I don't have another modem.
I have tried a few soft restarts, so perhaps that is the cause of the re-connections.
It is several years old now - is it time to update it?
David
