Like thick syrup
Weevie
Insightful One
Message 6 of 6
My connection is like  browsing through thick syrup - today
I have run speedtest and it appears good - except for an initial hesitation
What is going on ?
Any updates being downloaded to the router or something ?
Interestingly - just found that the NTP is failing to sync !!
5 REPLIES 5
Message 1 of 6
Bandsteering just switches between Wi-Fi frequencies for compatible devices as they move around.  If this is something you do not need, you can disable it.
Message 2 of 6
It did pick up a new ip address - so I presume that's good enough
Message 3 of 6
30 minutes is recommended for starting a fresh session that may improve speeds, @Weevie, not just 20.
30 minutes is a minimum.
Message 4 of 6
It is still slow but slightly faster than yesterday - I rebooted the router and left it for 20mins
Could you tell me how to delete an old phone that is no longer connected to the router - wirelessly - it is shown as existing but no ip address...
Also - should I disable BANDSTEERING ?
I have googled it - and it reckons that it causes more problems than it helps with network congestion
thanks
Message 5 of 6
Nothing going on that I'm aware of, and tests are clear.  Have you tried a reboot of the router or a 30 minute powerdown to clear the session.
