Mesh / range extender
on 30-12-2024 03:52 PM
Message 23 of 23
We're having problems with WiFi range in our house, using the TalkTalk WiFi Hub 2 (hardware details in the router portal say "FAST5464 2.00"). I'm looking at options for switching to a mesh network, but note a few discussions on here about a FAST266 range extender, apparently available direct from TT. Is this a sensible/compatible option here? If so, how would I go about getting hold of one?
Kind regards,
Jo
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
22 REPLIES 22
on 30-12-2024 04:18 PM
Message 21 of 23
Thanks Keith, that's helpful.
Is there a way to get to the loyalty dept specifically?
Happy to investigate our current setup further in the meantime - what would you suggest?
Kind regards,
Jo
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-12-2024 04:08 PM
Message 22 of 23
Hi @Josephiah
Yes, the 266 is a very good product & combines with your 5464 to form a mesh network. The only main limitation is that whilst the 266 works up to WiFi 6, the 5464 only accepts connections up to WiFi 5. If you just want one of these, rather than investigating the current state of your WiFi network, then you can contact the loyalty dept to buy one or more of them.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- « Previous
- 1
- 2
- Next »
