on 21-11-2023 05:49 PM
on 22-11-2023 08:25 AM
Hi Zack
There are no issues at TalkTalk side that will cause this. Like most services, Netflix will use Geolocation data for checking IP addresses accessing their services.
If you take your IP address and check it via any third party site such as What Is My IP Address - See Your Public Address - IPv4 & IPv6 (This will detect your IP Automatically) and give you information regarding your connection, general location and country, and also state if you are using a VPN Service etc.
Netflix will use a similar method to detect what country you are in when accessing their services.
If the registered info at TalkTalk end were incorrect in any way, it would be reflected at any of these third party websites.
This will show that the info or registered database that Netflix are using in this case is incorrect.
You can pass this info to Netflix with your IP Address and ask them to correct this, or turn off your connection for 30 minutes to see if a new IP address is issued to you.
