on 11-04-2023 09:11 PM
My TalkTalk fibre broadband was installed on 14th March (after 3 separate City Fibre engineer visits). We were told from the last City Fibre engineer that this would be sorted within 12 hours but it still isn't working. We are still using our old TalkTalk connection.
The ONT as part of the new connection is connected and has all the lights on but when an ethernet cable is connected to the Wi Fi hub or to a laptop directly it does not work.
I've tried multiple times explaining this on online chat and through phone calls but aren't getting anywhere.
Essentially, it just requires someone to allow the connection from either Talk Talk or City Fibre's end. Can you please help?
on 28-04-2023 02:39 PM
Hi Nikki,
Your connection still looks OK from our end, if you are still experiencing problems please let us know
on 27-04-2023 03:11 PM
Hi Nikki,
Could you let me know if this is now working, it all looks OK from our side
on 27-04-2023 12:58 PM
Hi Nikki,
I've just checked and your connection appears to be up and running now, is everything OK at your end?
on 27-04-2023 07:45 AM
OK, I've made a change which hopefully will fix the problem. The changed can take a few hours to take effect but hopefully it wont take that long
on 27-04-2023 07:39 AM
That's great Nikki thanks. I'll take a look at this now, I think I know what the problem may be and it's hopefully an easy fix
on 26-04-2023 08:23 PM
Hi Chris,
Is this what you mean?
Device Ver: FAST5364-3. T8
Sagemcom
Thanks,
Nikki
on 26-04-2023 01:01 PM
Hi Nikkimread,
Could you check the label on the router and tell me the make and model number
on 26-04-2023 12:27 PM
Hi Karl,
It appears my last message did not post properly. No, it is still not working.
Thanks,
Nikki
on 26-04-2023 09:55 AM
Hi Nikkimread,
I can only conclude that all is working now, but if there are any issues, please get back to us here.
on 17-04-2023 07:48 AM
Hi Nikki,
Just to confirm, is it still not working today?
on 16-04-2023 03:09 PM
Hi Karl,
Still not working I'm afraid.
Thanks,
Nikki
on 14-04-2023 11:55 AM
CityFibre have resolved an issue from their end, can you please retest the connection and let me know if it's working.
on 12-04-2023 08:20 AM
I've escalated this to our network teams to check the service for you.
