New power cable for WiFi hub
leerudd
Message 6 of 6
There was a brief power cut in Edinburgh and my WiFi stopped working. I have tried restarting the box, trying a different socket and everything else but the hub will not turn on. I think the fuse may have blown in the adapter/power cable. Is it possible to have a replacement sent out as soon as possible? I work from home so need WiFi. Thanks
5 REPLIES 5
Message 1 of 6
Just checking back in to see how you're getting on?
Message 2 of 6
No problem. It should fit through the post box and most arrive next working day 🙂
leerudd
Message 3 of 6
Thanks Chris.
Is there any chance you could direct message me some sort of tracking number so I can be in for the delivery or would it maybe fit through the post box?
Message 4 of 6
Hi leerudd,
I've ordered a replacement, it should be with you within a couple of days, you'll also receive a returns bag to send the old router back in
leerudd
Message 5 of 6
Just to add I would be happy to source a replacement cable for myself if that is quicker I just need to know what cable to get, I believe it's a Sagemcom WiFi hub
