No Internet - Flashing Orange and Blue light
Liz7263537
Message 32 of 32
Hello!
We’ve had no internet since the 2nd May and the router just continuously flashes orange and blue. Performed many troubleshooting steps as listed below:
- Tried resetting
- Tried Factory Reset via physical pin
- Left the router device off for over 20 minutes numerous times
- Tried different ADSL cable
- Checked for landline noise (clear line)
An Openreach engineer did visit the property today and replaced an extremely old master socket with a new Master Socket 5C but the issue still persists. Engineers diagnostic tools were able to detect our correct download and upload speeds and they mentioned the issue is most likely a faulty router as the router is able to sync but not connect via VDSL (engineer made a phone call to talktalk and processed a new router to be sent in the meantime).
My only worry is that the new router still won’t resolve the issue as we have a secondary older talktalk router and the problem still persists.
Talktalk live chat have stated the router isn’t able to provide a sync check result and have just advised to restart the router etc. (Is there an issue with authorisation?)
Anyone that can help with any line refresh/resets would be very much appreciated.
TalkTalk Wi-Fi Hub (Black device)
Router settings display all the correct sync speeds (showtime) but doesn’t seem to be able to make a VDSL connection as the status is stuck on “Connecting”.
31 REPLIES 31
Message 1 of 32
How are you getting on?
Message 2 of 32
Hi Liz7263537
I've been advised that this fault should now be resolved?
Message 3 of 32
Hi Liz7263537
I've requested an update this morning and I will post back shortly.
Message 4 of 32
Hi Liz7263537
Dani has just let me know that they will be investigating this fault this morning. I will let you know as soon as they come back to me with an update. Apologies the call dropped, it might be because of the tests they are running.
Message 5 of 32
I was called around 30 minutes ago by Danny within Case Management.. they said that they were going to attempt to “reset connection” put me on hold and then the call cut off? Not quite sure what’s going on ☹️
Message 6 of 32
Hi Liz7263537
Apologies again. I have escalated this straight back over to our Network Team and I will post back here as soon as I have further information.
Message 7 of 32
Hi Debbie,
We haven’t had internet since it worked for a for hours after the engineer left on Friday. The engineer stated the issue was that our account/configuration wasn’t setup/no where to be found, so he had to wait on the phone whilst talktalk did it all again manually.. after doing so our internet come back instantly… for a few hours then went off again.
Message 8 of 32
Hi Liz7263537
I'm so sorry to hear this.
Is this fault still happening today?
Message 9 of 32
Hi Debbie,
That didn’t last long.. we have the exact same issue again (no internet).
Engineer stated earlier today that there was nothing wrong with our property or the cabinet.. the issue was that our connection configuration/credentials were nowhere to be found on the network and had to be manually created/inputted again (engineer called talktalk whilst at the cabinet). and our service was restored instantly.
As of 22:00 tonight, left with no internet yet again with the exact same dhcp client failed errors within router logs 😞
Message 10 of 32
Hi Liz
I'm so glad to hear this 🙂
Hope you have a lovely weekend too 🙂
Message 11 of 32
Afternoon Debbie,
I can happily confirm we’re all back online now, solid white light following the engineers visit.
Wishing everyone a nice weekend 🙂
Thanks,
Liz
Message 12 of 32
Hi Liz7263537
I will check in with you later today once our Network Team have provided me with an update.
Thanks again.
Debbie 🙂
Message 13 of 32
Morning Debbie,
Thanks for the update, I believe they’re attending the cabinet this time around.. fingers crossed.
Message 14 of 32
Hi Liz7263537
Our Network Team have advised that another Openreach engineer visit has been arranged for 12/05/2023 AM.
I will continue to monitor for additional updates from our Network Team.
Message 15 of 32
Hi Liz7263537
Our Network Team have advised that they made contact with you yesterday and that they will be contacting you again today about this fault.
Message 16 of 32
Hi Liz7263537
Apologies for the delay. I'm still waiting on an update from our Network Team.
I will post back here as soon as they come back to me.
Message 17 of 32
Hi Debbie,
Had a call from TalkTalk earlier asking if the issue is still ongoing and did a RADIUS refresh.. issue is still persisting. Not sure if they were apart of the network team you’ve contacted?
No internet since the 2nd May and fault tracker states the issue is on TalkTalks end and an engineer is working to fix it.
Feeling quite hopeless now, hoping this is resolved soon.
Message 18 of 32
Hi Liz7263537
Ok, I've escalated this over to our Network Team for them to take a look.
I will post back as soon as I have further information.
Message 19 of 32
Hi Debbie,
We’ve already had an engineer out to the property, tested everything and all was ok with their diagnostic tools.. router is able to sync but isn’t able to make a connection via dhcp. They suspected it’s likely an authentication issue. Are you able to rebuild our profile in the meantime and perform a complete refresh?
Message 20 of 32
Hi Liz7263537
It could be. If you have tested with a different router, filter and cable at the test socket then the next step will be an engineer visit to the property.
Would you like me to arrange this visit?
