No Internet. Openreach little box on wall has a red LOS light
Mark61
Message 4 of 4
My Internet went down 3 days ago I have done all the usual resets, taking plugs out, taking all wires out and still no luck. I've notice the little open reach box on my wall has a red LOS light on. Tried to contact Talktalk with no luck. They are an absolute joke. Is there a number I can phone
3 REPLIES 3
Message 1 of 4
Morning Mark,
Do you still need assistance with this?
Chris-TalkTalk
Message 2 of 4
Hi Mark,
As fr8ys has said, if you can update your profile we'll be happy to take a look at this for you
Message 3 of 4
You can Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
Or you can wait until a support staff member responds to your thread in which case can you please details the steps you have tried yourself to rectify the issue, such as turning the ONT box off and turning back on. You will be asked this and more if you phone.
If you wish support staff to look into, for a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
