No internet connection solid red light on router
Joeycat909
Message 7 of 7
Hello, for the past 2 hours my broadband connection has been lost. The power light is green but the broadband light is staying red. The router is Hg633. I have done a line check and a problem was detected on the router. I have switched the router off for 20 minutes and powered back on but the problem remains. I have also done a factory reset with the router but still the problem remains. I have also checked all of the cables. I think this router has stopped working altogether. Is it possible to get a replacement sent out please? Thank you in advance.
6 REPLIES 6
Message 1 of 7
Message 2 of 7
Thank you very much.
Message 3 of 7
Hi Joeycat909
The router is on its way, please allow 48hrs for this to arrive.
Let us know how you get on.
Thanks again.
Message 4 of 7
Thank you. I have added the information to my profile. How long is it likely to take to arrive?
Message 5 of 7
Hi Joeycat909
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
Divsec
Message 6 of 7
Hi @Joeycat909 the team will be in touch shortly, I'm guessing the answer will be yes.
