Old Router
Badassclown
Message 11 of 11
Hi, my router is a old huawei hg633 router which iv had since i signed up with talktalk which is many years ago, and over the past 6 month or so the WiFi coverage seems terrible. Walking into the kitchen being on a video call says low signal strength, remote play isn't stable at all. Being upstairs is the same. The speed is fine, my nivida shield works fine in the living room, my phone does too. I'm wondering if I can get a Free Router Replacement to sort this issue out.
R.G
10 REPLIES 10
Message 1 of 11
Have you had a look at the below Help Guide?
Set up a non-TalkTalk router - TalkTalk Help & Support
Message 2 of 11
Hi Michelle, no I was just trying to setup the TP Link VX230v but its not connecting to the Internet?
I did read someone had to get their provider to verify the new routers mac address or something to get it to connect to the Internet?
R.G
Message 3 of 11
Thanks for the update. Can I just confirm, are you trying to connect 2 routers at the same time?
Message 4 of 11
Hi Michelle, I have received the router and its got better, WiFi. Im still having micro stutters with my ps portal. I have bought a tp link VX230v router. And it doesn't connect to my Internet I read I have to connect my isp, to get the mac address verified or something to make it connect?
R.G
Message 5 of 11
Great thank you 🙂
Michelle 🙂
Message 6 of 11
Thanks alot, and I will keep up to date
R.G
Message 7 of 11
Hi Badassclown
Thank you 🙂
Message 8 of 11
Hi, Debbie, I think iv now done what you asked me to do? Thanks.
R.G
Message 9 of 11
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send you a replacement router.
Divsec
Message 10 of 11
Hi @Badassclown yes we are all getting older! Your post has been escalated and you should hear tomorrow.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
