3 hours ago
Hi need a bit of advice.. for the past few months my ping spikes has made gaming nearly impossible.. always hardwired on the ps5.. jumps from 20ms right up into 500+
3 hours ago
OK, any particular games/servers, or generally? Have you run traceroutes to check for bottlenecks? Have you tried setting alternative DNS servers in your router?
3 hours ago
Straight from ps5 to router
3 hours ago
When you say hardwired do you mean directly from PS5 to hub via ethernet, or using any adapters:?
