Poor WiFi - new router?
richardsun
Message 8 of 8
Hi, we have issues with poor WiFi strength in our house. The house isn't massive so I suspect a newer/better router with dual band WiFi might solve the problem.
Current router is a Technicolor TG588 supplied many years ago by Shell Broadband.
I tried contacting TalkTalk support on the live chat to see if they would send me a new router, but didn't get any sense out of them.
I wonder if anyone on here can help?
7 REPLIES 7
Message 1 of 8
Hi richardsun
richardsun
Message 2 of 8
@KeithFrench thanks for the offer of help.
A friend has kindly donated me an old router, which appears to be better than the old TalkTalk one. Will see how it goes.
Message 3 of 8
Keith is free to try to help you it just that I can't send you a router, if a replacement new router is required this would have to be dealt with by the dedicated support team
Message 4 of 8
As I said @richardsun I can provide a lot of help with WiFi interference, which is possibly the cause, you only have to ask for that.
richardsun
Message 5 of 8
Thanks for your reply. I have already attempted to seek support on this via the chat service, but got absolutely nowhere after wasting far too much time repeatedly describing my problem to different people. I'm not going to keep wasting my time on this, will probably just move to a different provider with better support.
Chris-TalkTalk
Message 6 of 8
Hi Richard,
I'm sorry but if you're one of the shell migration customers there is a dedicated support team. If you contact customer service they be able to pass you to the right team, apologies for any inconvenience
Message 7 of 8
Yes, that should be the first logical step & if that does not solve the problem, then it is probably WiFi interference related & I can help a lot with that.
However, I do not know the policy & what router you might be entitled to, as you are an ex-Shell customer. I have therefore asked one of TalkTalk's support to pick your thread up and advise/replace it for you.
