Poor divice speed for router
Hbailey123
Message 4 of 4
Download speed from router is maximum 1Mb this is ridiculous as it seems there's 76MB coming to the router. I think I need a new router
3 REPLIES 3
Message 1 of 4
Hi Hbailey123
Do you still need help with this? Did you try the 30 minute power down of the router?
Message 2 of 4
Hi Hbailey123
Can I just check, have you tried powering down the router for a full 30 minutes and then running a speed test?
Message 3 of 4
What sort of devices do you have & how do they connect to the router, via Ethernet or WiFi?
