Problems with Huawei HG-633 Router
Juliberthay
Message 14 of 14
Hi, we currently use the Huawei HG-633 router, but within the last year we've been having many problems with it. The wifi often drops out and requires restarting the router. Sometimes the connection will drop out entirely (wired and wireless), but all of the lights remain flashing green, and again restarting the router temporarily fixes it. The wifi performance has also degraded, and has required that we use powerline to connect a TV at the other corner of the house, where previously we didn't need to.
As a long standing customer (over 10 years), would it be possible to receive a new router as a replacement? Thank you.
13 REPLIES 13
Message 1 of 14
Just checking back in to make sure that everything has been ok since your last post?
Message 2 of 14
OK thanks Juliberthay, just let us know if you need any further assistance
Message 3 of 14
Hi Debbie - we received the replacement router today - all set up and working. We'll keep an eye on it to make sure all continues to work fine. Thanks again.
Message 4 of 14
Morning @Juliberthay
The router is showing as dispatched. You should hopefully receive the router today.
Message 5 of 14
Hi Debbie - no, we haven't received the replacement router yet.
Message 6 of 14
Message 7 of 14
Hi Mugatu72
Please can you create a new topic on the Community, we can then take a look at this for you.
Message 8 of 14
@Mugatu72
Start your own topic and the support team will look at this for you when they are back online from Monday.
Mugatu72
Message 9 of 14
Having similar problems with my old router, been with tiscali/talk talk for years. How do I go about getting a replacement for this old tech?
Message 10 of 14
OK thanks. I've ordered a replacement router, it should be with you within 5 working days
Message 11 of 14
Hi Chris - yes, we've tried resetting the router to factory settings a couple of times now, but it doesn't make any difference and the problems mentioned soon appear again.
Chris-TalkTalk
Message 12 of 14
Hi Juliberthay,
I'm sorry to hear that you're experiencing problems with your router, have you tried resetting the router to factory default settings?
Message 13 of 14
That is quite an old device now, I am sure the support team here can replace it for you. You should get a response from them tomorrow.
