Re Contract Fibre 67
plb46
Whizz Kid
Message 39 of 39
I went through the process of recontract Fibre 67 as the renewal was May 2024 and the information came up that I would get 35 to 39 mbs and a Guaranteed 32.3 mbs At the moment my guaranteed speed is 42 mbs. The router is showing 43110 kps although I only get 35 mbs to my device. I cannot understand how I can recontract fibre 67 yet get shown the re contract  figures.
Why I only get 35 mbs I do not know as prior to my land line ie loss of dialling tone which was fixed I was getting 41 mbs to my device. An engineer came and checked the line etc but when he left I was only getting 33 mbs to my device but subsequently it went up to 35 mbs. Perhaps community support could give me some advice.
Plb46
38 REPLIES 38
Message 21 of 39
Hi plb46
Thank you. I will check the connection stats again on Monday and I will post back on this thread.
Message 22 of 39
Hi Debbie,
Yes ok I will connect the new router for 48 hours and see how the speed goes.
Thank you
plb46
Message 23 of 39
Hi plb46
Please can you keep the new router connected to the line for at least 48hrs to allow DLM time to monitor the connection and adjust the line profile/speed.
Message 24 of 39
Hello Debbie,
 Yes I Have received the router thank you. Unfortunately, the speed was slightly lower than my 3782 DSL Router. The new Router was giving a ethernet connection speed of around 33 to 35 mbs and the 3782 DSL was achieving 39 to 40.5 mbs. The DSL Router settings where showing 16400 / 43100 kps.
Do you want me to return the Router you sent .
Thank you.
lpb46
Message 25 of 39
Message 26 of 39
Message 27 of 39
Hi Debbie,
Thank you I will let you know.
lpb 46
Message 28 of 39
Hi plb46
Message 29 of 39
Hi Michelle,
Yes please as the engineer who came last time told me that I had an old router.
lpb46
Message 30 of 39
Ok, would you like us to send a replacement router for testing purposes to see how the connection/speed compares?
Message 31 of 39
Hi Michelle,
I have only have the DSL 3782 router no other one.
lpb46
Message 32 of 39
Are you currently using the 3782 router? Do you have an alternative router that you could test with please?
Message 33 of 39
Hi Michelle,
I have a D-Link Micro Filter DSL-35MF which came with my DSL 3782 Router. However I cannot see how we can connect as it has a DSL and Phone female connections one end and one male phone connector the other.
Plb46
Message 34 of 39
Did you try to connect the router using a microfilter?
Message 35 of 39
Hi Michelle,
I removed the face plate and attempted to connect to the master socket. However it did not seem to lock in so I did not get any Broad Band or internet connection. I tried with another cable but the same. Replaced face plate reconnected router with another cable. We are now getting to the router 41685 kps and using Talktalk speed test 39 mbs download and 14 mbs up load.
Lpb46
Message 36 of 39
Thanks for confirming. Do you mean that the router is currently connected to the test socket behind the faceplate?
plb46
Whizz Kid
Message 37 of 39
Hi Michelle,
My master socket is 5c and my router is plugged into it and my lap top is plugged via an ethernet cable to my Lap Top and I am getting a speed of 35.6 mbs.  My router is showing 43110 kps and the speed test is also showing 42 mbs to your router.
plb46
Message 38 of 39
Good morning,
I've run a test on the line now which hasn't detected a fault. Does your main socket have a test socket please?
