Replacement hub
on 18-08-2024 05:40 PM
Message 3 of 3
My WiFi hub stopped connecting. How do I get a replacement
Labels:
- Labels:
Connection
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 19-08-2024 08:05 AM
Message 1 of 3
Hi @Imdman12
Can I just check, have you tried a factory reset? (pin hole reset for ten seconds)
Please can you also add your name and TalkTalk landline number to your Community Profile.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-08-2024 05:49 PM
Message 2 of 3
What have you tried to get it working again?
Is the router connecting to the internet and it's just WiFi that's down?
Have you tried:
- Checking the WiFi hasn't been turned off accidentally (try pressing the WiFi button and see if that helps)
- Rebooting the router
- Turning it off for 30 mins and trying again
- Trying a factory reset by using the pin reset hole when the router is on so it reboots ( note this will reset any changes you may have made such as network name and password)
Please confirm and let us know how you get on.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
