on 10-11-2024 07:00 AM
Since 8:30pm last night my router (Sagemcom-FAST5364) has been blinking amber, it appears to completely cut out and then tries to start up again, leading to the constant amber blinking again.
I’ve run the tests on support and they do confirm there is an issue however when I do the further tests, the webpage errors out.
I think the router may well have died and I work from home so I’m a bit worried about what next week will bring!
Any recommendations at all?
on 13-11-2024 06:32 AM
Morning Ollie @Ewokcarrier
That's great, thanks for letting us know 🙂
I've sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 12-11-2024 10:03 PM
Hi Ollie so glad you are sorted. Any problems please come back.
on 12-11-2024 06:44 PM
Hi Debbie,
New router arrived and connection back up 🎉 and old router bagged, tagged and on its way back tomorrow.
Thank you both @Debbie-TalkTalk and @Divsec for your support.
Ollie
on 12-11-2024 06:34 AM
Morning Ollie
Thank you 🙂
on 11-11-2024 02:43 PM
Thanks for sending out so quickly, once it arrives I’ll get it plugged in and let you know!
Thanks,
Ollie
on 11-11-2024 02:42 PM
Hi Ollie @Ewokcarrier
Thanks again.
on 11-11-2024 07:27 AM
Morning Debbie,
If that would be possible it would be greatly appreciated, I’ve left the router on over the last day or so and it appears to be stuck in some sort of rebooting loop so I believe the router is at fault as opposed to the line thankfully!
Thanks,
Ollie
on 11-11-2024 07:22 AM
Hi @Ewokcarrier
The line test is clear, would you like me to send a replacement router for testing?
on 10-11-2024 11:33 AM
No luck with the power cycling unfortunately!
Will wait to hear back from support.
Thanks for your help regardless @Divsec
on 10-11-2024 07:26 AM
I did give the power out trick a go last night but didn’t have much success, I’ll give it another go in a bit and post back if any joy.
Not had any reports on the local Facebook group so figured it wasn’t an isolated incident!
on 10-11-2024 07:23 AM
Hi @Ewokcarrier worth a try, the team will be back tomorrow.
Another thought try disconnecting the router from power for 30 minutes then reconnecting. (Gives things at the exchange a chance to reset)
on 10-11-2024 07:16 AM
Thank you for your quick reply,
Unfortunately I don’t have another router anywhere though as we have had this one in place for a few years.
I will have a look around though and see if we do, I’ll give it a go if I do find one.
on 10-11-2024 07:11 AM
Hi @Ewokcarrier do you have a spare / old router to try with today?
Go to my account and find the test my connection section.
your post has been escalated and you should hear soon.
