fibre 46
alzinio
Message 12 of 12
what should the average speed of fibre 65
11 REPLIES 11
Message 1 of 12
Hi @alzinio
How are you getting on?
Message 2 of 12
Hi alzinio,
Are you running the speed tests wired or wired? Have you also tried powering down the router for a full 30 minutes as this will reset the current session?
AllyM
Message 3 of 12
Are you new to TalkTalk or have you been a customer for a while?
You say you are currently getting 26Mbps. Were you previously getting a higher speed?
Is that the router connection sync speed or a speed test result?
You say the cabinet is 200 yards from your house. Are you sure that is the cabinet you are connected to?
Have you tried searching your address here BT Broadband to confirm what cabinet you are connected to and the estimated speed predictions for your line?
martswain
Message 4 of 12
You should get full speedYou should get full speed
Message 5 of 12
Hi alzinio
Are you the account holder? Please can you send me a Private Message to confirm the name on the account.
Message 6 of 12
im currently getting 26mbps
Message 7 of 12
Then you should get near the top limit of your package.
Message 8 of 12
ive added my name and landline
alzinio
Message 9 of 12
the cabinet is about 200 yds from my house
Message 10 of 12
Hi @alzinio
Please can you add your name and TalkTalk landline number to your Community Profile, I can then check the predicted speed range for your line.
Message 11 of 12
If that is delivered via VDSL (Fibre To The Cabinet), it depends on how far you live from the Fibre cabinet.
