Router and Digital Voice
Funky-Gibbons
Whizz Kid
Message 17 of 17
Hoping for a bit of help here, last week had a free full fibre upgrade carried out,  the router I am currently using is a DG8021W-2T5 which doesn't have a digital voice socket, after asking the city fibre installer several times for a compatible full fibre router he handed over an open boxed previously used eero without an ethernet cable and no digital voice adaptor, customer services have now supplied me with an adaptor but the issue I now have is lack of electrical sockets as I wasn't aware the adaptor would also need power. As the eero also only has 2 ethernet ports it would mean I would also need to buy a 4 port switch for my other hardwired devices, again requiring a power outlet (I am already having to use an extension cable which isn't ideal as I had to use my only spare socket for the ONT). Would it be possible for talktalk to provide me with a WiFi Hub 2 router for return of the eero as I am now in the situation where my phone has been disconnected from the old copper network and I am unable to use digital voice.
Secondly if anyone now phones my landline number it goes directly to a voicemail service which I have not signed up for and is not on my telephone options plan, can I have this removed please as I don't want people leaving messages for me that I can't retrieve. Many Thanks.
Ready to learn something new today
16 REPLIES 16
Message 1 of 17
Hi Funky-Gibbons
I'm so glad to hear this, thanks for letting me know 🙂
Message 2 of 17
Update as promised,  turning on and then turning off voicemail 48 hrs later has resolved the issue,  thanks @Debbie-TalkTalk for the advice 👍
Message 3 of 17
Message 4 of 17
Thank you,  I will report back at the end of the week.
Message 5 of 17
Hi Funky-Gibbons
Thank you. I can credit this charge back for you after this testing.
Message 6 of 17
Yes I can try that, would this come as a charge on my account for turning on the VM boost? If so I may be better waiting until tomorrow to turn it on so there is only a charge for November
Message 7 of 17
Hi Funky-Gibbons
Please can you try switching on the VM option in My Account and then switch it off again in My Account in 24hrs?
Message 8 of 17
Good morning Debbie,  yes my phone does have one but it's not turned on by default,  when it is turned on it answers after 5 rings (approx  10 seconds), the TalkTalk voicemail is kicking in if I have not turned on my answer machine.
Message 9 of 17
Hi Funky-Gibbons
Can I just check, the handset you are using doesn't have a built in answerphone feature?
Message 10 of 17
@Chris-TalkTalk Hub2 router arrived and set up and digital voice is now up and running, however after phoning my own number the voicemail is still coming on after the phone rings for approximately 40 seconds, can you look into getting this stopped please, I've checked my boosts to make sure that voicemail hasn't been set up accidentally but it hasn't.  Thank you.
Message 11 of 17
Funky-Gibbons
Whizz Kid
Message 12 of 17
That's great thanks,  and yes okay I will check when the hub 2 is up and running.  I appreciate your help folks 👍
Message 13 of 17
Thanks. I've ordered the router, it should be with you within a couple of working days. If you are still experiencing the same issue with the new router just let me know and we'll look into it further
Message 14 of 17
Address added thanks Chris.
Would the voicemail service automatically stop once my phone is connected to digital voice or do you need to do something to my service to stop it?
Chris-TalkTalk
Message 15 of 17
Hi Funky-Gibbons,
I can arrange to send you a wifi hub 2, can you just add your address to the private notes section of your community profile and let me know when you've done this
Message 16 of 17
I will ask them for you, I thought it was standard now to supply the Hub 2 for digital voice. It is what is quoted in the FAQs anyway:-
https://forms.c-e.io/5090/oldZ8kt_p-KU4BN-c9Z6SQ
